Hi to all.
I am using system.alarm.queryStatus to build a dataset of the current state of the alarms (to access many properties).
I have a task where i need to show each alarm event (“ClearUnacked”, “ClearAcked”, “ActiveUnacked”, “ActiveAcked”) in a different row. This means that the results dataset i get from “system.alarm.queryStatus” shouldnt have the events combined into a single item.
I know i could use “system.alarm.queryJournal()”, but in this case i need the alarms from the gateway system and not from the journal, also, i dont want to use a time range or the last 8 hours (wich is used in the journal), i need all the alarm events in the gateway system (no matter the date/time)
How can i acomplish it?
Is it posible to alter “system.alarm.queryStatus” function?
Is there any other function?
