How to stop Ignition Perspective gateway so I can modify and save my ignition.conf
Hello!
i would like to modify my ignition.conf so I can have more memory for my perspective project with:
wrapper.java.maxmemory=4096
But I can´t as it´s running somewhere else, I guess the gateway. Can I stop the gateway for a while?
To start/stop your Ignition service, you can follow this doc from IA:
If you are running your gateway in a Windows machine with an interface, you can also start/stop/restart your gateway from Window's "Services" application.
Thanks Riccardo. This seem quiet complex, I wonder if I need do this to save my ignition.conf
Yes you do.
That utility is something you will need to become familiar with.
Thanks bschroeder
Hello!
In order to change the max memory, I stop my ignition with
and:
Then I go to my ignition.cofig to edit the max-memory
but I can´t save it
any ideas welcome!
You must be an admin to edit that file, same as for installing Ignition.
Yes!, thank you!
For Windows server 2012 and some others in order to edit ignition.conf as administrator
You have to
-run command propmt as administrator
-go to the folder in wich ignition.conf is
-type: notepad ignition.conf
-change the value of the wrapper.java.maxmemory
and save it!
Restart ignition later....
and then....no more memory issues :v: :muscle: :kissing:
