How to stop query in Designer so you can edit
Query for Audit log table is error out and unable to do edits to fix issue. Is there a way to stop it?
Or is only solution to delete page and re-create?
error is popping up faster then I can delete table or try to go to config.
Close the window. Shift-right-click on it in the designer tree and export the XML. Dig around in that to find the query binding. Cross your fingers and tweak in XML (or delete). Shift-right-click again to get the option to paste back.
Second button on the bottom left of the error window will toggle the popping up of the alarm window.
