Is there an easy way to do this? The number of columns is dynamic.
Not for a varying number of columns, out of the box. The built in sum() expression function will do a column at a time.
If you can programmatically determine which columns to include, you could use the forEach() function from my free Simulation Aids module to sum the sums. Something like this (for v8.1.8+):
sum(
forEach(
columnsOf({path.to.dataset}),
if(
{some.expression.yielding.true.to.include.column},
sum({path.to.dataset}, idx()),
null
The expression that determines whether to include a column can examine the column name as it()[0], the column type as it()[1] (in string abbreviated form), or the column index as idx().
sum() seems to work only with columns. I want to sum the rows.
Example input and output dataset, please. I'm pretty sure I can get forEach() to get you an answer.
