How to take back a UDT instance override via system.tag.editTag()?
Version 7.9.13
When using system.tag.editTag() what is the correct way to remove an override on a UDT instance?
Specfically, a child members OPCItemPath attribute.
I tried not specifying the override parameter in system.tag.editTag(pathToTag)
I tried specifying override={}
I tried specifying the specific tag with empty dictionary; overrides = {“ChildMember”:{}}
None of the above seem to be working.
Any insight would be greatly appreciated!
Have you tried setting the specific override to None?
Nailed it.
Thanks @witman .
This is what worked:
overrides = {“ChildMember”: {‘OPCItemPath’: None}}
