I am using Ignition 8.1.10. on Windows 10 from the standalone ignition zip. I put the “{PathToTag}” into the “Read Expression” on derived tag. It crashes the designer. I tried finding anything related to java in the task manager to stop it but to no avail. I stopped the Ignition, but still cannot close the designer applet. Anyone encounter this bug? Thanks.
Can you disable the tag?
Can you edit your question title to give a clue to a search engine reader what the issue actually is? I’ll delete this comment later. Thanks.
Solution: I rebooted the computer. Restarted Ignition again and delete the tag. However, for future, how do you stop a frozen designer in Windows without rebooting the computer? What is the name under the task manager?
