I’m getting many ComponentModel errors while a particular View is open, but I’m not sure how to find what the error is referring to in the View.
How would I go about diagnosing this?
This is the full error:
java.lang.IllegalArgumentException: Cannot set value of valuenode to a Object
at com.inductiveautomation.perspective.gateway.property.PropertyTree$ValueNode.setValueInternal(PropertyTree.java:1162)
at com.inductiveautomation.perspective.gateway.property.PropertyTree$ValueNode.(PropertyTree.java:1151)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.nodeFromJson(PropertyTree.java:326)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.nodeFromJson(PropertyTree.java:292)
at com.inductiveautomation.perspective.gateway.property.PropertyTree$ValueNode.write(PropertyTree.java:1213)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.lambda$write$1(PropertyTree.java:420)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.writeImpl(PropertyTree.java:463)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.write(PropertyTree.java:420)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.writeAll(PropertyTree.java:414)
at com.inductiveautomation.perspective.gateway.model.ComponentModel.onPropertySync(ComponentModel.java:449)
at com.inductiveautomation.perspective.gateway.model.ViewModel.lambda$onPropSync$5(ViewModel.java:324)
at com.inductiveautomation.perspective.gateway.model.ComponentModel.dispatch(ComponentModel.java:394)
at com.inductiveautomation.perspective.gateway.model.ComponentModel.dispatch(ComponentModel.java:400)
at com.inductiveautomation.perspective.gateway.model.ViewModel.onPropSync(ViewModel.java:321)
at com.inductiveautomation.perspective.gateway.model.PageModel$Handlers.lambda$onPropSync$18(PageModel.java:887)
at java.base/java.util.concurrent.CompletableFuture.uniAcceptNow(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.uniAcceptStage(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.thenAccept(Unknown Source)
at com.inductiveautomation.perspective.gateway.model.PageModel$Handlers.lambda$onPropSync$19(PageModel.java:885)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.lambda$mdcWrap$0(LoggingContext.java:41)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:210)
