How to trigger configureCell in power table and is it possible to know who triggered it?
Hello There,
I’m trying to figure out a smarter way of doing something.
I have a table which shows history status (Ok, Not Ok) of the batches through the different part of the process and they are color coded. Now, I also want to show the current status of the batch in different blinking colour in the same power table. I get this working right now by custom properties of the status. But, I am using data refresh to blink the light every 2 second. What happens essentially is that database is getting loaded a little with this. So, I am trying to find out a way to toggle configureCell some different way and also know who triggered so I can narrow down the cell updates.
Thanks,
As per my understanding, you want to trigger configureCell per 2 second.
Try it this way, place a timer component on that screen (it’ll be hidden automatically in runtime) and run timer per 3 second. In the configureCell check if timer value is greater or equal to 2.
Try binding the query to a custom property, then bind the data property to the custom property. It should just hit up the custom property and not trigger the query.
This topic has more detail on this subject:
This seems to be helping
