Hello People, I am running Ignition on KEBA T70 device.
The device have a keypad with buttons, which are configured to JOG in manual mode functionalities.
whenever I try to press button and if a text field is focused on the screen then its getting filled with alphabets. I tried using the following scripts in the event clients
event.source.setFocusable(0)
val=system.tag.read(’[default]Test_focus/key’)
if val.val:
root = event.source.parent
root.setFocusable(True)
root.requestFocusInWindow()
root.setFocusable(False)
It worked on my PC in vision client but not on the KEBA device.
Please share some ideas or suggestions on this issue.
Thanks in advance
