How to upload a Custom Theme from scratch using the Gateway API?
Trying to see if I can setup a Theme remotely using the Ignition API. I have gotten my API calls to read theme data and have used the create theme API endpoint to create the theme instance. Now, I am trying to figure out how to upload the customized CSS files. There isn't a create endpoint, so I am thinking I need to use this endpoint. Is that correct? If so, what is the expected payload? When I send the payload as Text/CSS I am getting empty responses from the Ignition Server. Any help is appreciated!
Note, I am using Ignition 8.3.8.
Related topic:
