I am trying to refence a tag in my queries but I keep getting weird errors. Any help would be appericated
SELECT Built
FROM View_ActiveOrders
Where Targetlineid = 50 And Orderid ='[DT Right Hand]New Tag'
One of the errors
Conversion failed when converting the varchar value '[DT Right Hand]New Tag' to data type int.
I was using that in the Named Queries
The Tag I am using is a refence tag which is set up as an int
Please show us how. Make it easy for us to help you. Provide details as requested.
SELECT Built
Where Targetlineid = 50 And Orderid = '[DT Right Hand]New Tag.value'
First, there's no way for SQL to tell that your string constant is supposed to be a tag. You need to use a value parameter. Then where you call the named query, you retrieve and supply the tag value to the parameter.
That's not how this works.
You need to pass the tag's value to the the named query where you're calling it.
Use a parameter in your named query (it looks like this :parameter).
https://docs.inductiveautomation.com/display/DOC81/Named+Queries
I will give this a try thank you
