I have created SOAP endpoint using Sepasoft Web services module. How to invoke the soap endpoint url using system.net.httpGet or system.net.httpPost . I tried the soap endpoint url using httpGet in script console and in browser I can see some HTML response but it is not the expected response as given be system.ws.runWebService.
If this is possible please let me know how to do it.
Existing
So first try doing that with system.net.httpPost, my setup is looking like it is expected only POST requests and not GET. If you put in your URL in a web browser it should give you an example request and response for the operation that you can use to create the header and message.
Either way though you will probably have to parse a HTML and XML message to get your data in the format you want it to be in.
