Hello! I Use MES 2.0 and I Create Script Function : “System.schedule.addScheduleEntry”
is Error "AttributeError: ‘com.inductiveautomation.ignition.common.script.Imm’ object has no attribute ‘schedule’ "
Please sent solution for problem
Thank you
Thank you
I can’t tell if your script is verbatim or not, but it should have a lowercase s in system. system.schedule.addScheduleEntry()
I do not have Sepasoft MES installed on my gateway and trying to use your function gives me the same error you are getting. I would check to make sure the MES module is installed on your gateway. Also I’m not sure if these functions will work or not in trial mode with time expired. If you are running the trial version, make sure your trial time is refreshed. If this doesn’t work, maybe contact Sepasoft instead.
Need Help? Create a Ticket, Email, Call, or Visit us Online | Sepasoft MES Solutions
