I’m a little confused. Because I thought there was built in functionality to display reports.
What exactly are you doing?
Hi Andrews,
Exactly you are saying is correct , but we are saving the image as byte array, So there is no path and not saved in a folder. that’s it’s have issues.
@pturmel s Automation Professionals' Blob Server Module might be of use for you.
Not applicable. Reports can directly handle blobs from the database. The issue appears to be showing an image in the report table from such a blob column of a dataset.
Did anyone find a solution? I have the same problem rn
