How to write a smart scripting
I need store 10 data into database
current is my stupid code:
query="""
		INSERT INTO [dbo].[RubberFuYeWidthData]
           ([RecordID]
           ,[SerNum]
           ,[Pcs]
           ,[IndexN]
           ,[Measured]
           ,[RecordTime])
     VALUES
           ,SYSDATETIME())
RecordID=event.source.parent.RecordID
SerNum=event.source.parent.getComponent('SerNum').text
Pcs=event.source.parent.getComponent('PCS').value
Measured1=event.source.parent.getComponent('Measure1').floatValue
Measured2=event.source.parent.getComponent('Measure2').floatValue
Measured3=event.source.parent.getComponent('Measure3').floatValue
Measured4=event.source.parent.getComponent('Measure4').floatValue
Measured5=event.source.parent.getComponent('Measure5').floatValue
Measured6=event.source.parent.getComponent('Measure6').floatValue
Measured7=event.source.parent.getComponent('Measure7').floatValue
Measured8=event.source.parent.getComponent('Measure8').floatValue
Measured9=event.source.parent.getComponent('Measure9').floatValue
Measured10=event.source.parent.getComponent('Measure10').floatValue
args1=[RecordID,SerNum,Pcs,1,Measured1]
args2=[RecordID,SerNum,Pcs,2,Measured2]
args3=[RecordID,SerNum,Pcs,3,Measured3]
args4=[RecordID,SerNum,Pcs,4,Measured4]
args5=[RecordID,SerNum,Pcs,5,Measured5]
args6=[RecordID,SerNum,Pcs,6,Measured6]
args7=[RecordID,SerNum,Pcs,7,Measured7]
args8=[RecordID,SerNum,Pcs,8,Measured8]
args9=[RecordID,SerNum,Pcs,9,Measured9]
args10=[RecordID,SerNum,Pcs,10,Measured10]
system.db.runPrepUpdate(query,args1,'EHCMES')
system.db.runPrepUpdate(query,args2,'EHCMES')
system.db.runPrepUpdate(query,args3,'EHCMES')
system.db.runPrepUpdate(query,args4,'EHCMES')
system.db.runPrepUpdate(query,args5,'EHCMES')
system.db.runPrepUpdate(query,args6,'EHCMES')
system.db.runPrepUpdate(query,args7,'EHCMES')
system.db.runPrepUpdate(query,args8,'EHCMES')
system.db.runPrepUpdate(query,args9,'EHCMES')
system.db.runPrepUpdate(query,args10,'EHCMES')
I write 10 times the code, how to use a smart solution to improve? thanks a lot
Create NamedQuery with parameter and just pass the parameter in dynamic way to get the same result using for loop.
At start, you’d better to learn basic python knowledge, like for loop,range , string format and so on.
Python script is easy and useful, you just need some time.
For this question ,using “for i in range(10):” will help a lot.
Using xrange(start, end), which generates numbers from start (included) to end (not included):
RecordID = event.source.parent.RecordID
SerNum = event.source.parent.getComponent('SerNum').text
Pcs = event.source.parent.getComponent('PCS').value
args_list = [
		RecordID,
		SerNum,
		i,
		event.source.parent.getComponent('Measure{}'.format(i)).floatValue
	]  for i in xrange(1, 11)
for args in args_list:
	system.db.runPrepUpdate(query, args, 'EHCMES')
Python’s basics are quite easy, and widely used so you’ll pretty much always find solutions on google.
I’ll also suggest reading PEP8’s recommendations regarding code style.
I would arrange to perform all ten inserts with a single SQL statement (multiple elements after VALUES). Like so, with programmatic generation of the SQL:
query="""
  ([RecordID], [SerNum], [Pcs], [IndexN], [Measured], [RecordTime])
VALUES
  %s;
""" % ",\n  ".join(["(?, ?, ?, ?, ?, SYSDATETIME())"] * 10)
container = event.source.parent
RecordID=container.RecordID
SerNum=container.getComponent('SerNum').text
Pcs=container.getComponent('PCS').value
Measures = [container.getComponent('Measure%d' % (n+1)).floatValue for n in range(10)]
allArgs = [z for z in [RecordID,SerNum,Pcs,n+1,x] for (n, x) in enumerate(Measures)]
system.db.runPrepUpdate(query, allArgs, 'EHCMES')
I think that allArgs should be:
allArgs = [ [RecordID,SerNum,Pcs,n+1,x] for (n, x) in enumerate(Measures) ]
or
allArgs = [ z for z in ([RecordID,SerNum,Pcs,n+1,x] for (n, x) in enumerate(Measures))]
otherwise you get
thanks for your code, this code is simple for my level to understand
@pturmel @zxcslo
I have try the code
query="""
VALUES
  %s;
#[[RecordID,SerNum,Pcs,n+1,x] for (n, x) in enumerate(Measures)] it will report fault
here is the fault code
	caused by Exception: Error executing system.db.runPrepUpdate(
  ([RecordID], [SerNum], [Pcs], [IndexN], [Measured])
VALUES
, [[21, u'EHC800-439598-2021-07', 1.0, 1, 36.0], [21, u'EHC800-439598-2021-07', 1.0, 2, 33.0], [21, u'EHC800-439598-2021-07', 1.0, 3, 38.0], [21, u'EHC800-439598-2021-07', 1.0, 4, 37.0], [21, u'EHC800-439598-2021-07', 1.0, 5, 32.0], [21, u'EHC800-439598-2021-07', 1.0, 6, 39.0], [21, u'EHC800-439598-2021-07', 1.0, 7, 37.79999923706055], [21, u'EHC800-439598-2021-07', 1.0, 8, 36.70000076293945], [21, u'EHC800-439598-2021-07', 1.0, 9, 24.799999237060547], [21, u'EHC800-439598-2021-07', 1.0, 10, 34.900001525878906]], EHCMES, , false, false)
	caused by GatewayException: Unable to decode arguments
	caused by InvalidClassException: failed to read class descriptor
Ignition v8.1.14 (b2022012711)
Java: Azul Systems, Inc. 11.0.13
thanks for your support code.
I got the list flattening part scrambled. Try this:
query="""
VALUES
  %s;
rows = [[RecordID,SerNum,Pcs,n+1,x] for (n, x) in enumerate(Measures)]
allArgs = [z for row in rows for z in row]
it works, thanks for your code that show me another solution to solve the problem
