HSQLDataStore - Error creating data cache db
I’m getting a handful of repeating errors revolving around HSQLDataStore …
… the message for the HSQLDataStore - Error creating data cache db is …
[quote]com.inductiveautomation.ignition.gateway.web.pages.config.systemconsole.LogViewer$SerializableLoggingEvent$ClonedThrowable: error in script file line: 20 file input/output errorerror file input/output error C:\PROGRA~1\INDUCT~1\Ignition\contexts\main\datacache\PLRM\PLRM.data (The requested operation cannot be performed on a file with a user-mapped section open) C:\PROGRA~1\INDUCT~1\Ignition\contexts\main\datacache/PLRM/PLRM.backup opening file - file C:\PROGRA~1\INDUCT~1\Ignition\contexts\main\datacache/PLRM/PLRM.data
org.hsqldb.jdbc.Util.sqlException(Util.java:363)
org.hsqldb.jdbc.Util.sqlException(Util.java:103)
org.hsqldb.jdbc.JDBCConnection.(JDBCConnection.java:3233)
org.hsqldb.jdbc.JDBCDriver.getConnection(JDBCDriver.java:285)
org.hsqldb.jdbc.JDBCDriver.connect(JDBCDriver.java:245)
java.sql.DriverManager.getConnection(Unknown Source)
com.inductiveautomation.ignition.gateway.history.stores.HSQLDataStore.createInitialDatabase(HSQLDataStore.java:124)
com.inductiveautomation.ignition.gateway.history.stores.HSQLDataStore.initialize(HSQLDataStore.java:54)
com.inductiveautomation.ignition.gateway.history.sinks.AbstractSink.tryToInit(AbstractSink.java:81)
com.inductiveautomation.ignition.gateway.history.sinks.AbstractSink.isAccepting(AbstractSink.java:98)
com.inductiveautomation.ignition.gateway.history.ForwarderThread.run(ForwarderThread.java:74)
org.hsqldb.error.Error.error(Error.java:112)
org.hsqldb.scriptio.ScriptReaderText.readDDL(ScriptReaderText.java:129)
org.hsqldb.scriptio.ScriptReaderBase.readAll(ScriptReaderBase.java:65)
org.hsqldb.persist.Log.processScript(Log.java:786)
org.hsqldb.persist.Log.open(Log.java:223)
org.hsqldb.persist.Logger.openPersistence(Logger.java:233)
org.hsqldb.Database.reopen(Database.java:265)
org.hsqldb.Database.open(Database.java:237)
org.hsqldb.DatabaseManager.getDatabase(DatabaseManager.java:225)
org.hsqldb.DatabaseManager.newSession(DatabaseManager.java:148)
org.hsqldb.jdbc.JDBCConnection.(JDBCConnection.java:3216)
com.inductiveautomation.ignition.gateway.history.ForwarderThread.run(ForwarderThread.java:74)[/quote]
… I’m working with Ignition 7.0.2.4482 on Windows Server 2003. I can provide more information if requested. Any ideas?
We’re looking into it. This is a problem that has been popping up here and there and seems to be an issue with the internal database that we use.
In the meantime, you might try deleting the files in “InstallDir\contexts\main\datacache” and see if that helps a bit.
Regards,
Ok, I’ve done just that … I’ll keep an eye on the logs over the next couple of days and let you know of any changes …
Thanks for the response …
