HsqlDataStore - Error deserializing data from data store
Hi All,
I found my gateway logs full of this error message ( one error each second ):
java.lang.ClassNotFoundException: com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournal$AlarmJournalSFData
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Unknown Source)
at java.base/java.io.ObjectInputStream.resolveClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.cluster.ModuleObjectInputStream.resolveClass(ModuleObjectInputStream.java:37)
at java.base/java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.base/java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject0(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject(Unknown Source)
at com.inductiveautomation.ignition.gateway.cluster.ClusterUtil.deserializeObject(ClusterUtil.java:96)
at com.inductiveautomation.ignition.gateway.cluster.ClusterUtil.deserializeObject(ClusterUtil.java:56)
at com.inductiveautomation.ignition.gateway.cluster.ClusterUtil.unzipAndDeserializeObject(ClusterUtil.java:90)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractDatasourceStore.deserializeObject(AbstractDatasourceStore.java:497)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractDatasourceStore.loadTransactions(AbstractDatasourceStore.java:570)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractDatasourceStore.syncdTakeNext(AbstractDatasourceStore.java:513)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractStore.takeNext(AbstractStore.java:213)
at com.inductiveautomation.ignition.gateway.history.stores.MultiStageStore.syncdTakeNext(MultiStageStore.java:165)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.synchedTakeNext(ForwarderThread.java:200)
at com.inductiveautomation.ignition.gateway.history.forwarders.RedundancyAwareForwarder.synchedTakeNext(RedundancyAwareForwarder.java:68)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:139)
From the first line java.lang.ClassNotFoundException: com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournal$AlarmJournalSFData I think it’s related to the alarm journal Store and Forward property ( Config>Alarming>Alarm Journal Profiles>Use Store and Forward), which is set to true
Any help on what is causing those error messages?
PS: The system is working fine
PS: Ignition 8.0.9
Cheers,
Did you recently upgrade from an older version? There’s data in the datastore that can’t be deserialized in the newer version of Ignition due to changes in the code.
Nope, last time I upgraded was 2020-02-27 and it was from 8.0.4 to 8.0.9
I noticed that in the Log folders, there is a file called system_logs.idb-journal that keeps to appear and disappear
The journal meta-file is a SQLite maintenance file - and only has to do with the logs DB, not the store and forward caches, which are HSQL file-based databases.
Ahm… ok
Do you know what can I check ?
Well, 8.0.4 is ‘old’ enough to not have the changes I described. 8.0.6 is when the remote alarm journal and remote audit log were introduced; which entailed a refactor internally that lead to this. The AlarmJournalSFData inner class just doesn’t exist in 8.0.6+ - so whatever data is in your datacache is from that older version. If you haven’t noticed any issues at this point, it should be safe to delete it from quarantine - which should prevent it from ever showing up again.
How should I do it ?
Well, if you can’t drop the records from the web interface, then you can delete the datacache entirely.
  1. If you can afford a little downtime, then disable your database connection. If not, then disable the disk cache in store and forward settings for the database.
  2. Navigate to ${ignitionInstallDirectory}/data/datacache/ and delete the entire folder with the name of your database connection.
  3. Re-enable the DB connection or disk cache. A new disk cache should be automatically generated.
The thing is that from the web interface I have nothing stored in quarantine, should I do the procedure you suggested anyway?
If you’re getting this error consistently, then yes. I think one issue is that this class cast exception isn’t being flagged as a failure that puts the records into quarantine.
Thanks a lot @paul-griffith!
I’m really happy about this forum! The Ignition community is the best!
Thanks again and have a wonderful day :slight_smile:
Hi All,
Just wanted to chime in and say I had this issue as well, upgraded from 7.9.14 and then to 7.9.16 with data in quarantine which caused HsqlDataStore to flood the logs. Deleting the folders as suggested resolved my issue.
