HTTP Error 500 Server Error
Hi All,
I'm currently having an issue opening a project on an Ignition Server. I am currently receiving an error that says:
HTTP ERROR 500 Server Error
URI:/data/perspective/login/project_new
STATUS: 500
MESSAGE: Server Error
There are actually two projects on this server, but only one of them receives this error. Both projects are inheriting the same parent project.
There was one error that I saw that may be a cause, but I'm not sure how to fix it:
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.gateway.auth.idp.NotFoundException
at com.google.common.util.concurrent.AbstractFuture.getDoneValue(AbstractFuture.java:592)
at com.google.common.util.concurrent.AbstractFuture.get(AbstractFuture.java:551)
at com.google.common.util.concurrent.AbstractFuture$TrustedFuture.get(AbstractFuture.java:111)
at com.google.common.util.concurrent.Uninterruptibles.getUninterruptibly(Uninterruptibles.java:247)
at com.google.common.cache.LocalCache$Segment.getAndRecordStats(LocalCache.java:2345)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2313)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2189)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2079)
at com.google.common.cache.LocalCache.get(LocalCache.java:4011)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:4034)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:5010)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl.getIdpAdapter(IdpAdapterManagerImpl.java:714)
at java.base/java.util.Optional.flatMap(Unknown Source)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.startupInternal(WebAuthSessionImpl.java:121)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.mdc(WebAuthSessionImpl.java:102)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.startup(WebAuthSessionImpl.java:128)
at com.inductiveautomation.perspective.gateway.session.SecuredPerspectiveProjectSession.onStartupInternal(SecuredPerspectiveProjectSession.java:615)
at com.inductiveautomation.perspective.gateway.session.SessionKernelWrapper.onStartup(SessionKernelWrapper.java:145)
at com.inductiveautomation.ignition.common.lifecycle.AbstractLifecycle.startup(AbstractLifecycle.java:18)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$FragileRunnableFuture.getValue(ExecutionQueue.java:286)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$FragileRunnableFuture.getValue(ExecutionQueue.java:275)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$FragileCompletableFuture.run(ExecutionQueue.java:266)
at com.inductiveautomation.ignition.common.util.TimedRunnable.run(TimedRunnable.java:21)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:239)
Caused by: com.inductiveautomation.ignition.gateway.auth.idp.NotFoundException: null
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl$IdpAdapterCacheLoader.load(IdpAdapterManagerImpl.java:157)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterManagerImpl$IdpAdapterCacheLoader.load(IdpAdapterManagerImpl.java:151)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3570)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2312)
... 21 common frames omitted
Any help would be appreciated, thank you!
Seems pretty clear that one project has invalid project authentication settings.
Just update the Identity Provider name under Project/General in Project Properties in the Designer
That should fix it.
