Hello all
I am trying to interact with Microsoft Azure to send messages to teams. To do this, it needs to send http, both gets and posts
I have my post command working in postman, but it does not work in ignition. I tried both system.net.httppost, and system.net.httpclient and then using said client to post, but neither work.
The data has to be sent as x-www-form-urlencoded which is set in the header (or the param for the direct call), but I cannot figure out how to set the body data.
code, with areas commented out due to keys
accessTokenURL = "https://login.microsoftonline.com/" + tenantID + "/oauth2/v2.0/token"
content_type="application/x-www-form-urlencoded"
#body
body= {
"grant_type":"client_credentials",
"client_secret":"<secret string>",
"client_id":"<id>",
"scope":"https://graph.microsoft.com/.default"
accessTokenResponse = system.net.httpPost(accessTokenURL, contentType = content_type,postData = body, throwOnError = False)
Thank you for your help
