httpCIient() HTTP Timeout from Project Script
v8.1.44
I have a project script with a top-level variable holding a reference to a system.net.httpClient()
client = system.net.httpClient()
In another project script, I reference the client variable to call an API.
client = logistics.api.http.client
apiMethod = 'locations'
url = logistics.api.http.formatUrl(apiClass, apiMethod)
session_token = logistics.api.http.getSessionToken()
params = {'session_token':session_token}
response = client.get(url, params=params)
Some days everything works perfect in the perspective project. Then other days, I get nothing but http timeout errors when calling the APIs. Copy/paste the URL into a browser and it runs perfect.
Gateway Error
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 2, in runAction File "", line 157, in refreshList at com.inductiveautomation.ignition.common.script.builtin.http.JythonHttpClient.send(JythonHttpClient.java:104) at com.inductiveautomation.ignition.common.script.builtin.http.JythonHttpClient.get(JythonHttpClient.java:308) at jdk.internal.reflect.GeneratedMethodAccessor1490.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.io.IOException: java.io.IOException: Unable to GET https://api.gpsinsight.com/v2/driver/list?session_token=<myToken>
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at org.python.core.PyObject.__call__(PyObject.java:422)
at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
at org.python.core.PyMethod.__call__(PyMethod.java:228)
at org.python.pycode._pyx185424.refreshList$2(:167)
at org.python.pycode._pyx185424.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyBaseCode.call(PyBaseCode.java:112)
at org.python.core.PyFunction.__call__(PyFunction.java:406)
at org.python.pycode._pyx185423.runAction$1(:2)
at org.python.pycode._pyx185423.call_function()
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1010)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:950)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:161)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:98)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:80)
at com.inductiveautomation.perspective.gateway.action.ActionDecorator.runAction(ActionDecorator.java:18)
at com.inductiveautomation.perspective.gateway.action.SecuredAction.runAction(SecuredAction.java:44)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:263)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:252)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:221)
at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException: java.io.IOException: java.io.IOException: Unable to GET https://api.gpsinsight.com/v2/driver/list?session_token=<myToken>
... 40 common frames omitted
Caused by: java.io.IOException: Unable to GET https://api.gpsinsight.com/v2/driver/list?session_token=<myToken>
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
... 37 common frames omitted
Caused by: java.net.http.HttpConnectTimeoutException: HTTP connect timed out
at java.net.http/jdk.internal.net.http.HttpClientImpl.send(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientFacade.send(Unknown Source)
at com.inductiveautomation.ignition.common.script.builtin.http.JythonHttpClient.send(JythonHttpClient.java:102)
... 42 common frames omitted
at java.net.http/jdk.internal.net.http.MultiExchange.toTimeoutException(Unknown Source)
at java.net.http/jdk.internal.net.http.MultiExchange.getExceptionalCF(Unknown Source)
at java.net.http/jdk.internal.net.http.MultiExchange.lambda$responseAsyncImpl$7(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.uniHandle(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniHandle.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeExceptionally(Unknown Source)
at java.net.http/jdk.internal.net.http.Exchange.checkCancelled(Unknown Source)
at java.net.http/jdk.internal.net.http.Exchange.cancel(Unknown Source)
at java.net.http/jdk.internal.net.http.MultiExchange.cancel(Unknown Source)
at java.net.http/jdk.internal.net.http.PlainHttpConnection$ConnectTimerEvent.handle(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl.purgeTimeoutsAndReturnNextDeadline(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$SelectorManager.run(Unknown Source)
Caused by: java.net.ConnectException: HTTP connect timed out
... 13 common frames omitted
That's pretty definitively not an Ignition problem. That is a network issue or firewall issue between your gateway and your API server. Or, perhaps, a rate limiter on the API server.
(Testing elsewhere is meaningless.)
You will need IT help to pinpoint it. You probably should use wireshark to capture traffic when this happens. It will almost certainly show unanwered SYN packets for the connection attempts.
As soon as I fired up wireshark on the gateway, it started working :man_facepalming: I'll have to wait for the next outage before I can capture anything.
I still haven't figured this out yet, but I wanted to note that every time I start getting timeout errors, opening WireShark on the gateway immediately fixes the problem. Note I'm not doing anything in WireShark, simply opening it. :thinking:
Gateway is on Windows, I'm going to guess? (I suspect your windows firewall, which WS has to modify to work with raw Ethernet frames.)
Yes, Windows Server 2019. The goal is to move to Linux at some point, but we aren't there yet.
