Hub and Spoke Gateway Setup - Sites with Central hub
I’ve managed to avoid more complex Ignition setups in the past, but that time is coming to an end..
Disclaimer: I haven’t put much thought into this as yet, just starting to think about it out of hours…
We have a project coming up where we’ll be designing an Ignition rollout that involves multiple sites and a central hub to view the status of all sites. There will be application redundancy at each location which matches their existing SCADA setup.
In their existing SCADA system, each site has the ability to show information from other sites as well. Taking this to an extreme, if they have 100 sites, I don’t know how I would manage the remote tag provider connections and the GAN connections required to facilitate this, nor what network traffic impact this would have on the network? I imagine that I would need 99 remote tag provider connections, 1 to each of the other sites, configured on all 100 site gateways, as well as the 100 RTP’s configured to each site on the central. That seems like a lot to manage and a lot of overhead.. In the existing SCADA, the tag address space is global, so there is no more configuration to be done in order to read tags from different sites. The clients just know how to get the data based on the project’s network configuration
Regarding the project setup, I imagine that I would have a global project or projects which all projects inherit from. I would have a project for each site, and a project for the central hub. Say I need to display exactly the pages or at least a subset on the central hub, I don’t know how I would structure the inheritance to make this possible, given that Ignition’s project inheritance is linear and not hierarchical. In the existing SCADA, you can inherit from multiple projects at once, in which case your site projects inherit from the global and your central project inherits from each site as well as the global projects, and it can then just make use of the resources in all of the site projects. In Ignition, the only way to do this with inheritance is by the central inheriting site A which inherits site B which inherits site C, etc. which finally inherits global. For 100 sites, this is extremely cumbersome to configure, but it also means that each site project is not runnable. I don’t know if this affects EAM if I have the central hub as the master configuration which pushes changes out to the sites.
I’m sure there will be a lot more questions as I investigate this more..
Edit: inheriting site projects could be dangerous if the site projects have project gateway scripts defined
I've got a client running a hub and spoke setup like you described with one hub and 7 spokes. Here's some details on the setup.
Network topology:
  1. Hub: full-fat Ignition gateway with unlimited clients. This is a beefy instance on a VM as it is connected to every device and will handle as many clients as needed. This VM also has a dedicated historian server instance.
  2. Spokes:
    a) In normal operation, each spoke just runs as a client of the hub.
    b) Each spoke also has an Edge gateway that serves as the fallback (edge/full may depend on how many devices the spoke needs to connect to in fallback - more on that in a minute). Each spoke gateway is running the same project as the hub gateway.
Project:
The project for all gateways (hub and all spokes) is the same. The windows/views are limited based on which gateway the client is viewing from. I used some of the built-in device tags that exist when a device is defined on the gateway to determine which gateway is being used.
Tags:
Each "area" where a fallback gateway is needed gets it's own tag provider. The hub will include all tag providers. The spokes will just have the one. The result is that each tag has 2 connections, which is not ideal but the tradeoff here is worth it, IMO.
Example:
Area 1 devices : RTU10, RTU11, RTU12
Area 2 devices : RTU20
Area 3 devices : RTU30, RTU32
There would be tags in the "default" provider to determine which devices exist on the gateway. The hub would have all 5, Area 1 fallback would have 10, 11, and 12. Area 2 fallback would have 20. Area 3 fallback would have 30 and 32. There would also be 3 providers, one for each Area.
Within the one "master" project that runs on all gateways you now limit which buttons/components are enabled/visible based on the determined "area".
Now you only have one project to maintain, although you do have to maintain multiple gateways and make sure you have EAM tasks set up (although you don't actually need the licensed version of EAM, the trial works because the tasks can just run on-demand as needed). Some notable EAM tasks: syncing UDT types between the "default" tag provider and all other tag providers. Sending tags to all agents. Sending project to all agents.
One thing that is difficult here would be security, as far as user login and things go, unless you're managing that outside of Ignition.
Full disclosure I haven't scaled a project to that level but my initial thoughts on it are 100 RTPs on each site is creating a mesh network not a hub and spoke model and you're already on the right track thinking that's not a valid route. Instead I would set up each site as a remote tag provider on your central hub then on the hub create another tag provider as your central tags and aggregate all the sites into that. Then go back to each of the sites and add the central tags as a remote provider.
So then all your data goes site A -> Hub -> site D. That being said, I have no experience if this is best practice nor how it'll look from a network efficiency / loading delay aspect.
I would consider having “regional” hubs, so maybe 4 regional hubs with 25 sites each, and then a central hub that connects to the 4 regional hubs (or some sort of mathematical combination of sites/hubs that makes sense).
I would also only have one master parent project, all other projects inherit from the master. Anything else just gets too convoluted, and then everyone just disables inheritance.
I would also run separate servers just for Perspective at the hub level. This makes tag processing and historian issues easily separated from UI issues.
Sounds like a fun project.
How much data are you talking about between sites?
Real time control? Occasional data access for charts/reports?
We run a hub spoke with 70+ gateways, mostly for historical data but also for reporting,charts, status, etc. I would not suggest trying to run actual control systems across the network like that though.
Also, you currently can only have a single EAM master gateway on the network. It can pull apps from different locations and push them, but it is a single point.
We have some gateways dedicated to historical work, and some for enterprise dashboards, we make use of WebDev on the hub for API access to data from other systems, we use gateway messaging for other data access on demand as well.
I can’t get into too many specifics here, but if you have any specific questions you can DM me and if I can share the information I will.
Brad Fischer at Inductive knows the EAM systems very well and can provide guidance on it.
Is Remote Tag providers what you really need? Or would an MQTT Broker be the better route. Each site only has to publish a value once rather than deal with potentially a bunch of remote gateways polling..
Also, MQTT makes it so if you are ever performing a major upgrade that has incompatibilities (like the 7.9-8.1 upgrade), your gateways don't care.
Hi Nick,
I would push for a single project and drive your application entirely on configuration. Project inheritance for me has always been a headache (multiple designers, delayed updates, etc) and is the last tool I reach for.
For 5-10 gateways the GAN is manageable from a configuration standpoint but anything past that I would look to decouple those connections to something like a broker like @tgarrison said.
Hope this helps!
Thanks all for the replies, I will get back to this topic, but currently my focus is on a couple of other projects so I haven't had a chance to look into this any further.
I’m interested in looking into MQTT further for this, although I've been scarred by MQTT before with disappearing tags and their history config..
Just remember that they disappear. MQTT Engine is NOT the place to do any tag config. Make reference tags in a regular provider and do your configurations/scripting there.
I almost think MQTT could get messy here also. If you have that many clients subscribing to all the tags from all sites, it's going to get messy also.
I think the hub and spoke may be better, but use proxy connections where you only connect each site to the hub, and configure each site to allow 2 hops and the hub to allow 1 hop. Then as you add new sites, you only connect them to the hub. If they REALLY want to be able to browse all tags from all providers, then you'd need to configure RTPs for each, but is that even reality, or are they really only reading from a couple other sites? The advantage of RTPs is that unlike MQTT w/SparkplugB where you get all the data at every site, you'd only get the subscribed tags via the gateway network.
If you were to use MQTT, you'd almost have to have Engine at the Hub and do RTPs from all the sites to the hub for the Engine provider so you could get only the data you wanted without having to set up RTPs for every site.
To receive buffered MQTT data for history retention if comms drops, I thought this was the only option? We tried everything to get buffered events to come through to the ref tag but nothing worked.
Haven't played with passing thru buffered history. Did you try an expression tag? Ref tags do have some limitations.. maybe that's one of them.
See this thread/post where I was able to get it working without using MQTT tags for history.
