Hyper SQL stored procedure doesn't return result set
I’m trying to call a stored procedure in Hyper SQL by using createSProcCall and execSProcCall. However, no result set is returned. The stored procedure works outside of Ignition though.
Hyper SQL uses a cursor to return a result set from the stored procedure. Are cursors not supported in Ignition when calling a stored procedure?
Did you import the JDBC driver for HyperSQL in your gateway?
Yes and I’m able to connect to the database. The add, update, and delete stored procedures are working.
Can you post the stored procedure?
This isn’t the actual stored procedure. But it functions the same as the real one.
CREATE PROCEDURE MY_SCHEMA.GET_DATA(
IN IN_ID VARCHAR(50)
READS SQL DATA
DYNAMIC RESULT SETS 1
BEGIN ATOMIC
DECLARE RESULTS CURSOR WITH RETURN FOR
SELECT
t.ID,
t.DESCRIPTION
FROM MY_SCHEMA.MY_TABLE t
WHERE
(IN_ID IS NULL OR t.ID = IN_ID)
ORDER BY t.ID
FOR READ ONLY;
OPEN RESULTS;
END;
You might find this SO post useful: https://stackoverflow.com/questions/4343078/jdbc-returning-empty-result-set
