I am not able to toggle the PLC output tag from Ignition
Hello everyone,
I have an NJ501 Omron PLC with one CJ1W-ID211 input card and one CJ1W-OC211 output card.
I am connected with the PLC through NJ drive and I am able to see the tags and connection; however, I am not able to toggle the PLC output whereas I am able to toggle another boolean global variable I created in my program. In the video below you see that I am able to toggle the “Bin1” tag which is a boolean global variable I created but I am not able to toggle the PLC output tag (J02_CH1_OUT001). When I toggle the PLC output tag I do see the light on the output card turn on for just half a second, so it is so quick that I can barely see it. Do I need to put a delay or something?
Thank you!
Is your PLC writing to the tag as well?
I figured the problem. There was a mistake in the program now it is fixed.
