Attaching code from common scope-
package com.inductiveautomation.examples.helperfunction;
import java.io.BufferedWriter;
import java.io.File;
import java.io.FileWriter;
import java.io.IOException;
public interface ModuleRPC {
String getDatabase(String DatabaseName);
public class ModuleRPCImpl implements ModuleRPC
public String getDatabase(String Databasename)
SRConnection con; int maxVal;
try{
con=context.getDatasourceManager().getConnection(Databasename);
maxVal= (Integer) con.runScalarQuery("SELECT max(accumulatorLevel) FROM History");
return "MAX_VALUE, " + maxVal;
finally
if(con!=null){
con.close();
code from clienthook-
package com.inductiveautomation.examples.helperfunction.client;
import com.inductiveautomation.ignition.client.model.ClientContext;
import com.inductiveautomation.ignition.common.licensing.LicenseState;
import com.inductiveautomation.ignition.common.script.ScriptManager;
import com.inductiveautomation.vision.api.client.AbstractClientModuleHook;
import com.inductiveautomation.examples.helperfunction.HelperFunctions;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class ClientHook extends AbstractClientModuleHook {
private final Logger logger = LoggerFactory.getLogger(getClass());
ModuleRPC rpc = ModuleRPCFactory.create(ModuleMeta.MODULE_ID, ModuleRPC.class);
System.out.println( rpc.getDatabase("DB"));
@Override
public void startup(ClientContext context, LicenseState activationState) throws Exception {
super.startup(context, activationState);
@Override
public void shutdown() {
super.shutdown();
@Override
public void initializeScriptManager(ScriptManager manager) {
super.initializeScriptManager(manager);
manager.addScriptModule("system.getDatabase",ModuleRPCImpl.class);
