Ignition Gateway 8.3.9
I tried deleting the certificates but after deleting some of them, they come back visible, is it a bug? (see gif below)
This does look like a bug, thanks for the report.
I noticed that if I change the deletion sequence, for example starting from the 3rd and going towards the bottom, it deletes them. Very strange.![]()
For now, you can delete them from the filesystem directly, if you have access.
Yes, i have access, what is path?
I think something like:
$IGNITION/data/config/local/com.inductiveautomation.opcua/client/security/pki/trusted$IGNITION/data/config/local/com.inductiveautomation.opcua/server/security/pki/trustedfor client and server respectively.
