I can't get my XY chart working with database
Hi all,
i put binding in dataSources:
i put name of axis like in query....
But i get message on chart No series properly configured...
UPDATED: i finally solved...
But still how to convert from line to column? If i Choose render: column. There is empty chart.
Regards
If render is line, chart is ok:
if i put render column i get:
One by one and with help i get results...
how are transformation works... I have bar chart right now... And also in query string. I would like to color selected bar where in query is string "MASTER"
I'm not exactly sure what you're asking here.
What do you want your chart to look like?
i want to color bar in chart if Part_Type is ETALON in yellow and magenta if KALIBER for example...
Hope it is understandable...
I would make each type a separate series, give it a higher zIndex (so it appears on top of the other series), then change the #.column.appearance props to the colors you wanted.
with different dataset or the same?
this is what i get
how is your chart configured? you can use the preformatted text option when you paste your props so it displays correctly.
file is to long so i am sending JSON file
chart.json (43.6 KB)
That's why you paste it as preformatted text so it gets a scroll bar...
@hw79, I've found there's a limit to the post length and some of the charts' JSON exceeds that. Splitting it into two posts is messy.
good to know, thanks!
I noticed you don't have anything in dataSources, is it a binding?
Yes from DB query...
My typical process is to bring in the dataset as a custom prop then on the binding of the dataSources prop transform it into an array of JSON objects like the documentation shows.
edit: Ignore this, I might be giving you some bad advice. Let me figure it out then I'll reach out to you.
I dont understand… do you have some example maybe… tnx for helping
I'm sorry but I've spent 2 days trying to get this to work and I just can't get it. Unfortunately, this is why I'm forced to use Apex Charts in my project because the XY chart component doesn't do columns how I need them to.
I apologize for keeping you waiting.
Okay, I apologize again, it was bothering me, so I took another stab at it.
Is this the result you're looking for?
YES this is it :slight_smile:
