My best guess (someone more knowledgeable is welcome to correct me):
- Take a gateway backup.
- On the Ignition computer, backup the folder
%Ignition Install Folder%\user-lib\jdbc. - Replace the JDBC jar with something your version of Java supports.
- You may need to restart the gateway.
Thanks, I removed the jdbc folder and restarted ignition and I don’t have that error anymore.
However, I followed the instructions on Inductive University Course to install the MySQL driver and created a connection but it still says faulted.
Here is the error I got. Please let me know if you have any idea what’s causing this error. Thanks.
java.lang.ClassNotFoundException: org.apache.commons.dbcp2.BasicDataSourceFactory
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.IgnitionGateway.createDataSource(IgnitionGateway.java:2808)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.<init>(DatasourceImpl.java:224)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.installDatasource(DatasourceManagerImpl.java:496)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$DatasourceRecordListener.recordUpdated(DatasourceManagerImpl.java:931)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$DatasourceRecordListener.recordUpdated(DatasourceManagerImpl.java:884)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.notifyRecordUpdated(PersistenceInterfaceImpl.java:179)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl.doNotifyRecordUpdated(RedundantPersistenceInterfaceImpl.java:111)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RecordUpdateListener.recordUpdated(RedundantPersistenceInterfaceImpl.java:407)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RecordUpdateMessage.notify(RedundantPersistenceInterfaceImpl.java:457)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RecordUpdateListener.receiveCall(RedundantPersistenceInterfaceImpl.java:390)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:47)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:966)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:1041)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:539)
8.1.13 (b2021122109)
Azul Systems, Inc. 11.0.13```
Did you pick a JDBC driver that is compatible with java 11 ? And did you deliberately switch from MS SQL Server to MySQL ?
