I have no vision module under project browser
Unsure if the program has changed and vision is removed or if it is just my case. Following video tutorials but cannot find the vision module that contains panels. Nothing I do, even the sample fails to bring it up.
You might not have the Vision module installed.
Check the modules page on the gateway.
Also, can’t tell from the cropped screenshot, but if you’re running Maker Edition there is no Vision module.
Oh! Yes, I’m using Maker. I’m guessing then I am fine without the vision module and have found a video series pertaining to the Perspective module. I’m assuming I can get most things done with that :slight_smile:
