I am setting up a TCP device and make the settings in the OPC-UA/Devices the device appears as Disconnected.
In the attached image we’ll show you how this network.
I need to activate the license? For so far I’m using the Trial of 2 hrs.
Device information see it through Hyperterminal.
I need to do to get communication with my Device
I await your quick response
thanks
RED.pdf (23.8 KB)
Hi
When I try to connect by TCP I get an error.
24/05/11 12:14:27 PM TCPDriver-aries - Error starting listener: TCPListener (192.168.1.95:3001)
It looks like the driver can’t connect for some reason to 192.168.1.95:3001. If you are running a current version of Ignition there should be a stack trace that also gets printed out with that error message. Can you find the stack trace or attach your entire log file for us to look at?
Hi, Kevin
this is the list of errors that I get.
Greetings.
error.doc (379 KB)
I need you to post or email the wrapper.log file. It can be found in the Ignition install directory, usually something like “C:\Program Files\Inductive Automation\Ignition”.
Hi Kevin.
I send the document you request
wrapper.log.zip (402 KB)
It looks like the error is just a simple networking error:
INFO | jvm 1 | 2011/05/24 11:27:37 | ERROR [TCPDriver-Prueba1 ] [11:27:37,695]: Error starting listener: TCPListener (192.168.1.95:3001)
INFO | jvm 1 | 2011/05/24 11:27:37 | java.net.ConnectException: Connection refused: connect
INFO | jvm 1 | 2011/05/24 11:27:37 | at java.net.PlainSocketImpl.socketConnect(Native Method)
INFO | jvm 1 | 2011/05/24 11:27:37 | at java.net.PlainSocketImpl.doConnect(Unknown Source)
INFO | jvm 1 | 2011/05/24 11:27:37 | at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
INFO | jvm 1 | 2011/05/24 11:27:37 | at java.net.PlainSocketImpl.connect(Unknown Source)
INFO | jvm 1 | 2011/05/24 11:27:37 | at java.net.SocksSocketImpl.connect(Unknown Source)
INFO | jvm 1 | 2011/05/24 11:27:37 | at java.net.Socket.connect(Unknown Source)
INFO | jvm 1 | 2011/05/24 11:27:37 | at java.net.Socket.<init>(Unknown Source)
Either you have the IP address and/or port wrong or the device is refusing the connection. Have you tried pinging the device from the server that the Ignition gateway is running on and making sure it’s reachable?
Hi kevin.
I have a question
There any special port to communicate over TCP?
The only port you need to know is the one for the device you are trying to communicate to.
Just to make sure:
The way the TCP driver works is it makes a connection from the gateway out to a device with the specified IP address listening on the specified port. It then listens for that device to send data.
