How do I create an alarm filtering with calendars
What are you trying to accomplish? Which components exactly are you trying to use?
I want to make an alarm filtering using calendars
Ok, well you can bring down either two dropdown calendars or a date range component. With either you will have a start date and end date. To filter alarms you need to bring down a table component and bind the data property to the Function binding selecting Alarm History. You can use the start date and end date in the filtering criteria. I think this is what you are looking for.
yes, that is.
but as I can do?
What?
I think this it what you want to do. Hope you can see the detail clearly enough:
[youtube]PoySrx6evA8[/youtube]
Regards,
