I need to shift the x axis label in a trend
Dears,
I need to shift the x-axis label or find a way that the time appear just under the right bar .
check this photo below to get what I mean :
What component is that? Is it a Time Series chart?
it is xy chart
in xAxes array
add in target object "dx" it will help you to change the a horizontal offset
I think there's something else wrong. Users shouldn't have to do that and if it fixed the problem for this instance it would break if the x-axis time range changes to a different number of days.
Please copy the chart from the Project Browser and paste it in here. Be sure to format it as code using the </> button. You may need to disable the dataSources bindings so that we get data rather than just the binding configuration and no data. (You could test by pasting into a new view to make sure it all renders correctly.)
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "title": {
        "appearance": {
          "color": "#FFFFFF",
          "font": {
            "weight": 12
          "padding": {
            "bottom": 15
      "subtitle": {
        "appearance": {
          "color": "#FFFFFF"
      "legend": {
        "position": "top",
        "markers": {
          "width": 10,
          "height": 10
        "labels": {
          "text": "{name}[/]",
          "font": {
            "size": 12,
            "color": "#FFFFFF"
      "enableTransitions": true,
      "scrollBars": {
        "horizontal": {
          "enabled": false
        "vertical": {
          "enabled": false
      "selection": {
        "enabled": true
      "background": {
        "render": "color",
        "gradient": {
          "direction": "radial"
        "color": "#C0C0C000"
      "xAxes": [
          "name": "datetime",
          "label": {
            "enabled": true,
            "text": "datetime",
            "color": "#FFFFFF"
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": 0,
              "endCategory": 1,
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
              "skipEmptyPeriods": false
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "M/d/yyyy HH:mm:ss",
            "format": "d/M HH:mm:ss"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "logarithmic": false,
            "break": {
              "enabled": false,
              "startValue": 1,
              "endValue": 54,
              "size": 1
            "format": "#,###"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "#FFFFFF",
              "opacity": 1,
              "rotation": 90,
              "verticalCenter": "top",
              "horizontalCenter": "left"
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": 20,
              "position": 1
            "font": {
              "size": "",
              "weight": 500
          "appearance": {
            "font": {
              "size": "",
              "weight": 500
            "grid": {
              "color": "",
              "dashArray": "",
              "minDistance": 20,
              "opacity": 1,
              "position": 1
            "inside": false,
            "labels": {
              "color": "#FFFFFF",
              "horizontalCenter": "left",
              "opacity": 1,
              "rotation": 90,
            "opposite": false
          "category": {
            "break": {
              "enabled": false,
              "endCategory": 1,
              "size": 0.05,
              "startCategory": 0
          "date": {
            "baseInterval": {
              "count": 1,
              "enabled": true,
              "skipEmptyPeriods": false,
              "timeUnit": "hour"
            "break": {
              "enabled": false,
              "endDate": "",
              "size": 0.05,
              "startDate": ""
            "format": "d/M HH:mm:ss",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "inversed": false,
          "label": {
            "color": "#FFFFFF",
            "enabled": true,
            "text": "datetime"
          "name": "datetime2",
          "render": "date",
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "value": {
            "break": {
              "enabled": false,
              "endValue": 54,
              "size": 1,
              "startValue": 1
            "format": "#,###",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "visible": true
      "yAxes": [
          "name": "Pallet",
          "label": {
            "enabled": true,
            "text": "Cases Prodcution Per Month",
            "color": "#FFFFFF"
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "yyyy-MM-dd kk:mm:ss",
            "format": "M/d/yyyy HH:mm:ss"
          "value": {
            "range": {
              "max": 300,
              "min": 0,
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
            "format": "#.0a"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "#FFFFFF",
              "opacity": 1,
              "rotation": 0,
              "verticalCenter": "middle",
              "horizontalCenter": "middle"
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": null,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
          "appearance": {
            "font": {
              "size": "",
              "weight": 500
            "grid": {
              "color": "",
              "dashArray": "",
              "opacity": 1,
              "position": 0.5
            "inside": false,
            "labels": {
              "color": "#FFFFFF",
              "horizontalCenter": "middle",
              "opacity": 1,
              "rotation": 0,
            "opposite": true
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05,
              "startCategory": ""
          "date": {
            "baseInterval": {
              "count": 1,
              "enabled": false,
              "timeUnit": "hour"
            "break": {
              "enabled": false,
              "endDate": "",
              "size": 0.05,
              "startDate": ""
            "format": "M/d/yyyy HH:mm:ss",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "inversed": false,
          "label": {
            "color": "#FFFFFF",
            "enabled": true,
          "name": "Pallet2",
          "render": "value",
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "value": {
            "break": {
              "enabled": false,
              "endValue": 100,
              "size": 0.05,
              "startValue": 0
            "format": "#.0a",
            "range": {
              "max": 300,
              "min": 0,
              "useStrict": false
          "visible": true
          "appearance": {
            "font": {
              "size": "",
              "weight": 500
            "grid": {
              "color": "",
              "dashArray": "",
              "opacity": 1,
              "position": 0.5
            "inside": false,
            "labels": {
              "color": "#6FCDED",
              "opacity": 1,
              "rotation": 0,
            "opposite": false
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05,
              "startCategory": ""
          "date": {
            "baseInterval": {
              "count": 1,
              "enabled": false,
              "timeUnit": "hour"
            "break": {
              "enabled": false,
              "endDate": "",
              "size": 0.05,
              "startDate": ""
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "inversed": false,
          "label": {
            "color": "#6FCDED",
            "enabled": true,
            "text": "Capacity Percentage"
          "name": "Percent",
          "render": "value",
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "value": {
            "break": {
              "enabled": false,
              "endValue": 100,
              "size": 0.05,
              "startValue": 0
            "format": "#,###.##",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "visible": true
      "series": [
          "name": "",
          "label": {
            "text": "FG Pallets production rate per hour"
          "visible": true,
          "hiddenInLegend": false,
          "defaultState": {
            "visible": true
          "data": {
            "source": "ds_Total",
            "x": "datetime",
            "y": "Pallet"
          "xAxis": "datetime",
          "yAxis": "Pallet",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{dateX.formatDate('dd/MM/yyyy HH:mm')}: [Bold]{valueY.formatNumber(\"#,###.0\")}[/] Pallets",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "column",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "deriveFieldsFromData": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "#EC4B3D",
                "opacity": 1
              "stroke": {
                "color": "#EC4B3D",
                "opacity": 0.5,
                "width": 1
              "stacked": true,
              "width": 30,
              "height": 50,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "#8B1919",
                "min": "#FFE8CC",
                "dataField": "Cons"
          "line": {
            "open": {
              "x": "Month",
              "y": "Cons"
            "appearance": {
              "connect": false,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "#00FFFF",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "text": "{name}: [bold]{valueY}  {valueX}[/] cases",
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "text": "{name}: [bold]{valueY}[/]",
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "#0000FF",
                "opacity": 1
              "heatRules": {
                "dataField": "Cons",
                "enabled": false,
                "max": "#8B1919",
                "min": "#FFE8CC"
              "height": 50,
              "stacked": true,
              "stroke": {
                "color": "#0000FF",
                "opacity": 0.5,
                "width": 1
              "width": 30
            "open": {
              "x": "",
              "y": ""
          "data": {
            "source": "Shipping_out",
            "x": "datetime",
            "y": "Pallet"
          "defaultState": {
            "visible": true
          "label": {
            "text": "FG Pallets shipping rate per hour"
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#00FFFF",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": false,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "Month",
              "y": "Cons"
          "name": "",
          "render": "column",
I was not able to put the chart even after deleting the bindings in a one comment ,Thats is why i divided it in two comments.
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
          "visible": true,
          "yAxis": "Pallet2",
          "zIndex": 0
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "#EC4B3D",
                "opacity": 1
              "heatRules": {
                "enabled": false,
                "max": "#8B1919",
                "min": "#FFE8CC"
              "height": 50,
              "stacked": true,
              "stroke": {
                "color": "#EC4B3D",
                "opacity": 1,
                "width": 1
              "width": 30
            "open": {
              "x": "",
              "y": ""
          "data": {
            "source": "Percentage",
            "x": 0,
            "y": 1
          "defaultState": {
            "visible": true
          "label": {
            "text": "Percentage"
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#00FFFF",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": false,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": 0,
              "y": 1
          "name": "Percentage",
          "render": "step line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                    "text": "{dateX.formatDate('dd/MM/yyyy HH:mm')}: [bold]{valueY}[/] %"
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": "{dateX.formatdate(\" \"YYYY-MM-DD hh:mm:ss\"\")}: [Bold]{valueY.formatNumber(\"#,###.0\")}[/] Cases"
          "visible": true,
          "yAxis": "Percent",
          "zIndex": 0
      "style": {
        "backgroundColor": "#FFFFFF00",
        "marginLeft": 10,
        "paddingLeft": 20
      "dataSources": {}
    "meta": {
      "name": "XYChart_1"
    "position": {},
    "custom": {}
dataSources at the bottom of your second post is empty.
Try copying just the dataSources property into a post and see if you get data.
script_v0.txt (38.5 KB)
check pls the whole chart here .
That text file contains the bindings and no data.
datasources.txt (445.5 KB)
I'm able to reproduce the XY Chart now, thanks.
I suspect that rotate : 90 is rotating the label about the top left corner of the label and this is swinging it to the left of the rotation point. The XY Chart is based on AM Charts components and you can find some of the relevant documentation here:
https://www.amcharts.com/docs/v4/concepts/axes/positioning-axis-elements/#Label_rotation
I can't see a way to modify the verticalCenter property through the XY Chart properties though.
@Ahmed_mohamed's solution may be the best workaround for now.
Comments:
  • You can delete xAxes.1 as it's not used.
  • You can clean up the Percent graph by making the bullets transparent.
    series.2.appearance.bullets.0.fill.opacity : 0
    series.2.appearance.bullets.0.stroke.opacity : 0
    You need to leave them enabled if you wan the tooltip to appear.
You might be interested in some tooltip formatting that I figured out and shared in Perspective XY Chart xAxes tooltip text {dateX}.
