I see warning messages in the log from a logger named DatasourceImpl.java:300
I’ve seen that same logging in other threads but have yet to see anything about what is generating them.
The latest message I have seen is as follows:
java.sql.SQLException: Cannot get a connection, pool error Timeout waiting for idle object
at org.apache.commons.dbcp2.PoolingDataSource.getConnection(PoolingDataSource.java:142)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:582)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: java.util.NoSuchElementException: Timeout waiting for idle object
at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:321)
at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:428)
at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:232)
at org.apache.commons.dbcp2.PoolingDataSource.getConnection(PoolingDataSource.java:134)
... 11 more
8.1.17 (b2022051210)
Azul Systems, Inc. 11.0.15
20230726error3
Can anyone give me some insight into this logger?
That log message you posted refers to your faulted MSSQL database connection. I believe either the DB is down/unreachable, or you may have maxed out your connection pool(default is 8 max). Maxing out your connection pool can lead to your database connection faulting.
Where did you see this?
What are the contents of the $IGNITION_INSTALL_DIR/user-lib/jdbc folder?
Hello. I'll attach a screenshot
Please check.Thanks a lot.
Thank you very much.
