I have installed the IAlabs module into the Ignition Edge platform to utilize the sytem.tags functions, when launch the project nothing comes up. After looking into the console I see errors stemming from this module, see screenshot .
The functions from the IA Labs module were rolled into Ignition a while ago, you shouldn’t need that module any more.
First, provide your script, or at least the line where you’re specifically calling editTag.
Second, ensure you’re not running into a legacy permissions error: https://docs.inductiveautomation.com/display/DOC79/Project+Properties#ProjectProperties-ClientPermissions
Thank you, yes it was the Client permissions that were causing the problem. After allowing the role in the properties the function worked perfect, thanks all for your time.
