I would like to connect the VIPA PLC (Vipa 315-2ag12) to Ignition with IHB Link S7++.
The IBH Link is all default settings just the IP address is different. In the network I can ping this IP address, but the Ignition can't connect this PLC.
In the Ignition, the device connection is all default setting. I select the S7-300 PLC and set the right IP address.
My question is, where and what should I setting to make this a good? On the IBH Links or on the Vipa PLC or on the ignition?
I am really new in the Ignition programming so I am really open any idea!
If you need more information just write it!
Usually, I do this with the PC adapter via MPI, but if this module is inserted, I can also connect to the PLC via Ethernet through the module and program it.
No, it doesn't.
In Trial, Ignition is running for 2 hours, after that YOU have to manually reset the trial to start again... if you don't, then nothing works...
