I’d like to change the timer delay inside the timer script
For example execute step 1,2,3 with 5000ms delay, and step 4 and 5 with 6000ms
I’d try to modifiy the delay inside the timer script, but no effect while running.
Any idea to acheive it ? ![]()
The best way I can think of is to set the timer to 1000ms and create a custom property that sets the value depending on what second it is in an expression binding. Something like:if({Root Container.Timer.value}<5,
1,
if({Root Container.Timer.value}<10,
2,
if({Root Container.Timer.value}<15,
3,
if({Root Container.Timer.value}<21,
4,
5))))The only problem is deciding where to put the custom property, because you can’t add one to a timer component.
Bobby’s method will work best for Gateway and Client Timer Scripts, since there’s no way to change the time base on them.
On a timer component, though, you can bind the Delay property with this expression:
switch({Root Container.Timer.value}+1,
3,6,8,
2000,6000,4000,
1000)
The ‘+1’ is needed because the actual delay timing lags by one Value count.
Perfect! That looks even better than my solution, Jordan.
