Ideal way to display objects on a screen
Let’s say I have a large object on a components.custom property and want to display it, how would some of you do this? When I bind the object to a Label it’s quite hard to read.
I’d like to see the object in runtime in this format:
Any ideas or suggestions?
Markdown component paired with the jsonFormat expression would be ideal, although I confess I’m not positive the expression will directly work with perspective objects at present. If that fails, you could do the same thing, but with Python’s builtin pprint module instead; the script transform would just be:
import pprint
return pprint.pformat(value)
This is returning null for me in 8.1.1.
Oh, right. pprint automatically dumps to stdout. You want pprint.pformat:
https://docs.python.org/2.7/library/pprint.html#pprint.pformat
Doens’t return null :slight_smile: but returns a single line string :frowning:
Using jsonFormat() expression seems to give me the format I want in the markdown.source viewer but onscreen it looks like a single line string.
I tried using json.dumps but that seems to create another set of issues in the Transform but works fine in the Script Console. :thinking:
"```\n" + jsonFormat({value}) + "\n```" in an expression transform works pretty well, although it’s reading the nested props as QVs…
That's odd but it beats anything else thus far. Thanks @paul-griffith
For something you can use in a script transform (though you should probably put this into a project scoped script). Also, make sure you only attempt to use it from Perspective contexts:
	from com.inductiveautomation.ignition.common import TypeUtilities
	from com.inductiveautomation.perspective.common import PerspectiveModule
	gson = PerspectiveModule.createPerspectiveCompatibleGson()
	json = TypeUtilities.pyToGson(value, gson)
	return "```\n{}\n```".format(gson.toJson(json))
The triple backtick surrounds are to tell the Markdown component that it’s preformatted text, and thus to preserve line breaks and render with a monospaced font - just like code blocks on the forum.
I put it in the project library scripts and it works from the script console but when I call it from the markdown.source transform, I get ImportError: No module named perspective
A project library called format, defined as:
def json(value):
Is working for me, in both the script console and a design session:
Mimicked your setup but same import error… I’ll have to circle back around to this tomorrow and try again.
Wondering if I'm experiencing an issue with 8.1.1-STABLE that is not present in the version you're running?
Can't seem to get around the import error from this line:
Error reported:
Where are you running your code?
markdown.props.source
I am getting the same error about not being able to import perspective module in the property binding transform of the mark down component source.
I assume this only worked for @paul-griffith because he was running Ignition in the IDE…
Another solution, which involved more scripting, is to use the Tree component to display your JSON/Document data.
I went with the expression transform approach. Thanks.
Here is a way to do it without using an expression. @paul-griffith can comment if there is anything bad here, but avoids the use of the other library that can’t be imported.
def toDict(perspective_object):
	"""Formats a perspective object as Dict
	Adapted from http://forum.inductiveautomation.com/t/ideal-way-to-display-objects-on-a-screen/41575
	Args:
		perspective_object: A perspective property object
	# Convert the Perspective property object to Gson and back to a Py Object
	return TypeUtilities.gsonToPy(TypeUtilities.pyToGson(perspective_object))
def toMarkdown(perspective_object, indent=3):
		"""Formats a perspective object as Markdown
		Args:
		from json import dumps
		json_string = dumps(toDict(perspective_object), indent=indent)
		return "```\n{}\n```".format(json_string)
