Identity provider failed import
I try to connect to an identity provider with openID connect 1.0. When i try to import from url or json it says import failed.
Where can we saw why the import is failed ? Nothing appears in the logs of ignition.
Thanks in advance
Arnaud
Hi De_Clerck_Arnaud,
Can you provide a screenshot of the error you are receiving? Also, have you tried checking your wrapper logs yet? If you need help locating your wrapper logs, please refer to this article:
If you need further assistance, please feel free to reach out to Support here:
https://inductiveautomation.com/support/
hi @Eric_Byrd,
That's the only error i get. Even in the wrapper log i do not find anything about this.
When i enter the data manually then i get it working (At least i get the Idp loging page but the received user data cannot be parse).
thanks in advance for your help
You should open a support ticket. Then IA can get the right person to tell you what loggers to put into DEBUG or TRACE mode before you try the import again.
That's done a few minutes ago.
Thanks for the feedback @pturmel
Did you ever fix this issue? I am experiencing the same thing and can't get my identity provider working correctly.
