Hello everyone, I used OpenID Connect 1.0 to create Identity Providers. When I filled in all the parameters and executed Test Login, I was able to successfully redirect to the login interface. However, after logging in, I did not return any information and checked the log with an error message.The redirect URI for this Ignition Gateway is https not http,Will there be this reason?
com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterException: Unable to parse the WebAuthResponse from the HTTP request
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapter.parseAttributes(IdpAdapter.java:122)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.onLoginResponseInternal(WebAuthSessionImpl.java:245)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.lambda$onLoginResponse$3(WebAuthSessionImpl.java:270)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.mdc(WebAuthSessionImpl.java:109)
at com.inductiveautomation.ignition.gateway.auth.idp.WebAuthSessionImpl.onLoginResponse(WebAuthSessionImpl.java:270)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapterConfigRoutes$TestLoginWebAuthResponseHandler.handle(IdpAdapterConfigRoutes.java:301)
at com.inductiveautomation.ignition.gateway.auth.federation.FederationRoutes.callback(FederationRoutes.java:274)
at com.inductiveautomation.ignition.gateway.auth.federation.FederationRoutes$CrossSiteRouteHandler.handle(FederationRoutes.java:122)
at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:254)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:64)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:59)
at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:38)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:558)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:379)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:146)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
Caused by: com.inductiveautomation.ignition.gateway.auth.web.strategy.WebAuthStrategyException: Unable to exchange the auth code for the token
at com.inductiveautomation.ignition.gateway.auth.web.strategy.oidc.OIDCWebAuthStrategy.parseWebAuthResponse(OIDCWebAuthStrategy.java:204)
at com.inductiveautomation.ignition.gateway.auth.idp.IdpAdapter.parseAttributes(IdpAdapter.java:112)
... 57 common frames omitted
Caused by: com.inductiveautomation.ignition.gateway.auth.oidc.client.service.OIDCClientServiceException: Unable to execute HTTP request
at com.inductiveautomation.ignition.gateway.auth.oidc.client.service.HttpOIDCClientService.doGetToken(HttpOIDCClientService.java:288)
at com.inductiveautomation.ignition.gateway.auth.oidc.client.service.HttpOIDCClientService.getToken(HttpOIDCClientService.java:331)
at com.inductiveautomation.ignition.gateway.auth.web.strategy.oidc.OIDCWebAuthStrategy.parseWebAuthResponse(OIDCWebAuthStrategy.java:202)
... 58 common frames omitted
Caused by: java.net.UnknownHostException: 这是在主机名解析时通常出现的暂时错误,它意味着本地服务器没有从权威服务器上收到响应。 (login.microsoftonline.com)
at java.base/java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
at java.base/java.net.InetAddress$PlatformNameService.lookupAllHostAddr(Unknown Source)
at java.base/java.net.InetAddress.getAddressesFromNameService(Unknown Source)
at java.base/java.net.InetAddress$NameServiceAddresses.get(Unknown Source)
at java.base/java.net.InetAddress.getAllByName0(Unknown Source)
at java.base/java.net.InetAddress.getAllByName(Unknown Source)
at org.apache.http.impl.conn.SystemDefaultDnsResolver.resolve(SystemDefaultDnsResolver.java:45)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:112)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:376)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56)
at com.inductiveautomation.ignition.gateway.auth.oidc.client.service.HttpOIDCClientService.doGetToken(HttpOIDCClientService.java:286)
... 60 common frames omitted
