IdP and Attributes mapping
Hi, I need guidelines to set up OKTA IdP and the attributes mapping. Please provide a link or guidelines. Thank you
What I've done with other IdP's is that I set up the connection, then do a test login to see how the data is returned to Ignition, then use the JSON from the test login to map the attributes.
