Hi everyone! Hoping someone has a good idea on custom domain names for Ignition and can help me out. I am currently so close to having my test Ignition setup perfectly. I have two issues right now I can't seem to figure out. Domain changed for privacy.
I have a custom domain and certificate installed and they are working great and I can access Ignition internally and externally, but when I do a test login from my IDP the request always attempts go to: https :// customdomain/... as opposed to https ://login.microsoft.com. It works fine if I just use https:// localhost:8043 instead of my custom domain. I am sent to Microsoft, can login and redirected back to test login.
The other issue is despite the IDP settings saying my redirect uri is https:// customdomain... when I click test login I always get a redirect_uri of https:// localhost:8043
I have made sure the redirect uri's are setup in Entra and they do work perfectly if just using localhost:8088 or 8043
I have a reverse proxy from my IIS for customdomain on port 80 to 8088 and 443 to 8043. Which again is working great internally and externally except for the IDP and test login mentioned.
I have the following settings:
Also forse ssl on
