Hi guys!
I have a table from which I pick I pick a url for IE viewer depending on the selected row:
On the surface, this works okay, but each time a different cell is clicked, even in the same row, the viewer refreshes on the mouse press and mouse release.
Any thoughts on how I can reduce the number of refreshes?
It seems that it is refreshing every time the selectedRow changes on the table. Instead you can put a mouseClicked event on the table which checks for the selectedRow and refreshes the IE viewer. Something like:table = event.source
data = table.data
selectedRow = table.selectedRow
if selectedRow != -1:
event.source.parent.getComponent("IE Viewer").url = data.getValueAt(selectedRow, colIndex)
Well, you see the selectedRow property goes from -1 to the value when the dataset reloads or when you change the selected row. This causes other property bindings to refresh. In scripting you are guaranteeing that it happens once.
