If statement error?
Is this if statement correct?
if(({[default]Phase 1 Extrusion/PMR2/PMR2_Residence_Time_Target}-1.9) <= {this.props.text},'Green',
	if(({[default]Phase 1 Extrusion/PMR2/PMR2_Residence_Time_Target}+1.9) >= {this.props.text},'Green',
	if(({[default]Phase 1 Extrusion/PMR2/PMR2_Residence_Time_Target}-4.9) <= {this.props.text},'Yellow',
	if(({[default]Phase 1 Extrusion/PMR2/PMR2_Residence_Time_Target}+4.9) >= {this.props.text},'Yellow',
	if(({[default]Phase 1 Extrusion/PMR2/PMR2_Residence_Time_Target}-5.0) <= {this.props.text},'Red',
	if(({[default]Phase 1 Extrusion/PMR2/PMR2_Residence_Time_Target}+5.0) >= {this.props.text},'Red','Red'))))))
assume the time_target is 32 and the props.text is 32.9
Your parenthesis look OK but there is a much better way! Use a Map Transform.
A map transform is simple and easily debugged!
Pay attention to the use of ( ), [ ], ( ] and [ ) to define the bounds of each range.
Is there a problem with it not working correctly right now? If so I would guess its that you're doing a comparison of floats on a string object and you may need to type case {this.props.text} to a float.
Thanks I get it now.
I misunderstood the question originally. I've updated my answer.
Don't forget to mark one of the answers as the solution. It may help someone else.
