I think @Joachim_Govender wants to connect to his IFM sensors through the UDT and Perspective Templates he downloaded from Exchange.
That can be done after you've imported the UDT structures and you create instances of them through the Multi-Instance Wizard. The parameters require you to specify the hostname and port of the sensors:
That is how you can connect to each sensor based on its corresponding UDT.
