Iframe caching for Perspective Workstation
We have a webserver we are using to present work instructions, but it seems like after we updated one of the images, Ignition is still loading the old version. Is there a way to reset the cache in Perspective workstation?
In vision I would typically reset the cache on an image component or reboot the gateway, but I'm not sure if that applies when I'm guessing the client does more of the caching in perspective.
Cleared cache for workstation in the file system and we are good for now after setting up the client again. Not sure if there is a more straightforward solution for the future. Its not something that should change very often for this customer, so I don't know if adding a parameter to our URL is worthwhile as I've seen recommended.
Might be nice to have a button in workstation to clear the cache like you would in your web browser does so it isn't as much of a power user function to leave the application and clear it manually.
