Hi community, I'm having problems trying to get an html through scripting using httpPost. The idea is to return this html to an IFrame component through a binding property (using src property of component).
The code is this:
url = "https://mydomain.com/system/webdev/myApp/renderSQL"
print system.net.httpPost(url,'application/json',{"content": "ExampleParam"})
When I execute the code through script console in the designer it works, but when I execute in a binding property, it throws error
IOError: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Also I tried change domain to localhost and does not works, Any ideas on how I can achieve this?
