[IGN-10341]Error when using database transaction when a project does not have a default database
Why does a project need a default database connection when using transactions?
txID = system.db.beginTransaction(database = "LocalMYSQL")
query = """
	INSERT INTO test(MyAge)
	VALUE (?)
s = system.date.toMillis(system.date.now())
system.db.runPrepUpdate(query, [s], tx = txID)
system.db.commitTransaction(txID)
system.db.closeTransaction(txID)
Java Traceback:
File "", line 8, in
VALUE (?)
, [1721058713492], Transaction datasource 'LocalMYSQL', 40dd3b55-0c8e-4529-9d8e-4bac72824631, false, false)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:268)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(
VALUE (?)
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:553)
at org.python.core.PyObject.call(PyObject.java:400)
at org.python.pycode._pyx21.f$0(:10)
at org.python.pycode._pyx21.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at org.python.core.Py.exec(Py.java:1747)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(
VALUE (?)
... 25 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Connection Error: Unable to find project's default datasource.
Because of a coding mistake on our part; the check for "does this database name exist" happens unconditionally (when a DB query is invoked from the client/designer, at least) before the transaction ID is evaluated.
Note 1: This is not (ever? no longer?) an issue on the gateway side of things. It only affects client (designer/vision) calls. Still an issue in 8.1.52 and 8.3.6
Note 2: Vision scripts require the default db to be set.
Note 3: If you have a valid transaction in a script console, the db connection you pass in does not have to be valid -- any garbage string will do.
Has this been resolved or is there a plan to do so?
It's still a bug sitting in our backlog. Evidently it survived the refactoring the RPC system got in 8.3, which I guess is a testament to us maintaining bug-for-bug compatibility :upside_down_face:
The state of things right now would be to resolve this in 8.3.x only.
