[IGN-13095]WebDev Depends On EventStream module
Just noticed this on the build I downloaded yesterday (internal dates are June 2).
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Unable to load hook class "com.inductiveautomation.webdev.gateway.GatewayHook" for module "com.inductiveautomation.webdev".
	at com.inductiveautomation.ignition.gateway.modules.ModuleInstance.loadHook(ModuleInstance.java:588)
	at com.inductiveautomation.ignition.gateway.modules.ModuleInstance.load(ModuleInstance.java:262)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.loadModules(ModuleManagerImpl.java:301)
	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.init(ModuleManagerImpl.java:157)
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1025)
	at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:338)
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:785)
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$2(IgnitionGateway.java:710)
	at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:550)
Caused by: java.lang.NoClassDefFoundError: com/inductiveautomation/eventstream/RegistryItem
	at java.base/java.lang.Class.getDeclaredConstructors0(Native Method)
	at java.base/java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
	at java.base/java.lang.Class.getConstructor0(Unknown Source)
	at java.base/java.lang.Class.getDeclaredConstructor(Unknown Source)
	at com.inductiveautomation.ignition.gateway.modules.ModuleInstance.loadHook(ModuleInstance.java:566)
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.eventstream.RegistryItem
	at java.base/java.net.URLClassLoader.findClass(Unknown Source)
	at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:37)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.loadClass(ModuleClassLoader.java:85)
I was trying to prune my test environment down to a minimum. :man_shrugging:
Womp womp. I'll get a ticket going.
