[IGN-13145] Event Stream Showing Not Running
If you have the Event Streams dashboard open on one of your Event Streams in Designer, reboot the gateway and do not exit the Designer. When the Designer reconnects to the Gateway, the open stream is listed as "stopped" when it is in fact running.
To fix, disable the stream, save and re-enable the stream then save again. Now it will work fine in the Designer.
Hello David, this is a known issue our dev team is actively looking into. Thanks for checking out our new feature and posting the current work around!
