[IGN-14057] Problem with changing folder name in image management
Hello,
I noticed an issue with renaming a folder in image management. I found a post that mentioned this problem a few years ago. I’m wondering if it has resurfaced in version 8.3. I’m attaching a screenshot – is anyone aware of this?
Best regards,
Michał Góralczyk
Is there with every attempt to rename, or only particular folder(s)?
Can you go to the 'Details' tab, copy the full stacktrace of the error and paste it here as a preformatted text block? See how to post code on this forum.
In my case, I can’t change any folder. I download the images, delete the folder, and create another one – for now, that’s the only workaround I know. I’m using allowed characters.
java.lang.IllegalArgumentException:
	at com.google.common.base.Preconditions.checkArgument(Preconditions.java:129)
	at com.inductiveautomation.ignition.common.resourcecollection.LastModification.update(LastModification.java:30)
	at com.inductiveautomation.ignition.gateway.images.ImageManagerImpl.lambda$copyImage$3(ImageManagerImpl.java:212)
	at java.util.stream.ReferencePipeline$3$1.accept(:0)
	at java.util.stream.ReferencePipeline$2$1.accept(:0)
	at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(:0)
	at java.util.stream.AbstractPipeline.copyInto(:0)
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(:0)
	at java.util.stream.AbstractPipeline.evaluate(:0)
	at java.util.stream.AbstractPipeline.evaluateToArrayNode(:0)
	at java.util.stream.ReferencePipeline.toArray(:0)
	at java.util.stream.ReferencePipeline.toList(:0)
	at com.inductiveautomation.ignition.gateway.images.ImageManagerImpl.copyImage(ImageManagerImpl.java:214)
	at com.inductiveautomation.ignition.gateway.images.ImageRpcImpl.renameImageFolder(ImageRpcImpl.java:117)
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(:0)
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(:0)
	at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(:0)
	at java.lang.reflect.Method.invoke(:0)
	at com.inductiveautomation.ignition.gateway.rpc.RpcDelegate$DelegateRpcHandler.handle(RpcDelegate.java:271)
	at com.inductiveautomation.ignition.gateway.rpc.RpcRoutes.lambda$handle$1(RpcRoutes.java:199)
	at com.inductiveautomation.ignition.gateway.rpc.RpcRoutes.safelyHandle(RpcRoutes.java:219)
	at com.inductiveautomation.ignition.gateway.rpc.RpcRoutes.handle(RpcRoutes.java:198)
	at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:361)
	at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:120)
	at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:133)
	at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:40)
	at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:614)
	at org.eclipse.jetty.ee10.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1379)
	at org.eclipse.jetty.ee10.servlet.ServletHolder.handle(ServletHolder.java:736)
	at org.eclipse.jetty.ee10.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1614)
	at com.inductiveautomation.catapult.filters.GatewayFilter.doFilter(GatewayFilter.java:116)
	at jakarta.servlet.http.HttpFilter.doFilter(HttpFilter.java:97)
	at org.eclipse.jetty.ee10.servlet.FilterHolder.doFilter(FilterHolder.java:208)
	at org.eclipse.jetty.ee10.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1586)
	at org.eclipse.jetty.ee10.servlet.ServletHandler$MappedServlet.handle(ServletHandler.java:1547)
	at org.eclipse.jetty.ee10.servlet.ServletChannel.dispatch(ServletChannel.java:819)
	at org.eclipse.jetty.ee10.servlet.ServletChannel.handle(ServletChannel.java:436)
	at org.eclipse.jetty.ee10.servlet.ServletHandler.handle(ServletHandler.java:464)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:575)
	at org.eclipse.jetty.ee10.servlet.SessionHandler.handle(SessionHandler.java:717)
	at org.eclipse.jetty.server.handler.ContextHandler.handle(ContextHandler.java:1060)
	at org.eclipse.jetty.rewrite.handler.RewriteHandler$LastRuleHandler.handle(RewriteHandler.java:159)
	at org.eclipse.jetty.rewrite.handler.Rule$Handler.handle(Rule.java:108)
	at org.eclipse.jetty.rewrite.handler.HeaderPatternRule$1.handle(HeaderPatternRule.java:89)
	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:143)
	at org.eclipse.jetty.server.Handler$Sequence.handle(Handler.java:805)
	at org.eclipse.jetty.server.Server.handle(Server.java:182)
	at org.eclipse.jetty.server.internal.HttpChannelState$HandlerInvoker.run(HttpChannelState.java:662)
	at org.eclipse.jetty.server.internal.HttpConnection.onFillable(HttpConnection.java:418)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:322)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:99)
	at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:478)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:441)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:293)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:201)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:311)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:979)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1209)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1164)
	at java.lang.Thread.run(:0)
Ignition v8.3.0-beta4 (b2025081810)
Java: Azul Systems, Inc. 17.0.15
I opened a bug ticket for this.
