I have just installed Maker 8.1.10 on my Raspberry Pi 4 (64 bit OS), with an exposed IP of 192.168.1.198
After kicking off the system from the Pi I accessed the GW from my Mac and it all seemed good. I went through the installation and licensing process of the GW without any issue.
I then downloaded and installed the designer launcher from the GW as per the standard instructions. However when I went to run the designer launcher I received this dialog box.
I’ve only ever previously accessed my Ignition test systems from my Windows boxes, so I don’t know how to get around this on my Mac. So what is the solution?
